lorenambrose
From the wheel article in the tech section, I see that a 15" wheel should have a backspace of 3.75 in. giving it a -19mm offset. However when I look at different wheel manufacturers the sane 15x8 wheel whit a 3.75" backspace has a wide range of offset numbers. If I am understanding this right, offset is in reality the same measurement but expressed metrically. I could be wrong though. Can someone explain this to me?
Also the 7 and 8 inch wide rims have the same 3.75" recommended backspace. This would push the rim out 1" if using the 8 instead of the 7. How can the backspace be the same for both wheels? What is the real recommended backspace for a 15x8 wheel for a 2003 Ranger Edge.
