help w/electrical
W8S SS
i posted basically the same thread in the introductions forum but here's the problems i face with my 97 ranger i just bought last night...hopefully someone can shed some light unlike my haynes manual
4x4 not working- i know the automatic hubs suck so i'll probably go to manuals, hoping thats teh problem
windshield wipers and cruise control not working- the wipers are hard wired now so i'm hoping its a fuse or relay
interior light not always turning off- it didnt work last night when i bought it so i checked the fuse and it was blown. put a 20 amp in there and it only shuts off when it wants too now
door ajar light on- dont have a clue what this could be
i can't find a diagram of my fuse box on my truck or in the haynes manual so is there one online i can print up?
thanks for taking the time to help me out!!!!
One project at a time. If you register your vehicle on ford website you can get access to the owners manual. The owners manual will have the fuse box diagram.
thanks for the help. i downloaded the manual and checked all the fuses. everything looks good. now i'm going to autozone to pop new relays in to see if that will fix the wipers dilemma. if that doesnt work, what should i try next?
befor throwing parts at your truck with the hopes of fixing it, try saving some money, and spending more TIME. Check the relays to see if they are still good first.
If your dome light isn't turning off and your door ajar light is on that means you probably have a problem with a door switch. so id by start checking that.
i read soemwhere that if you spray wd40 on the latch of the doors, it can free up the connection for the door ajar sensor...sure enough i sprayed both doors and the light is off the dash and the dome light works great! i disconnected the battery to clean the terminals and the check engine light is off now and the 4x4 doesnt flash anymore. autozone doesnt sell the relays so maybe i'll try ford tomorrow. hopefully the relay for the wipers and cruise control is the problem so i can stop worrying about it. as far as spending time and money on it, i have both but this is my DD so its not my pride and joy...i got my SS for that :icon_hornsup:...thanks for the help so far though!
Does the dome light change (on/off, off/on) when you open the door or start/shutoff the vehicle?
