Help! Theft light is on
ttepkk29
United States
Help! Just bought a 2000 Ford ranger XLT 3.0l. Tried to change the fuel sending unit on it and now the theft light is on. It cranks but won't start. Giving me a 16 code. We've tried everything to reset it. Nothing is working. Can anybody help me out? How can I reset it, bypass it, anything. How can I get the truck to start? TIA
Man, stealing a 2000 ranger?
There has to be easier targets out there... can't imagine you make much chopping one that old nowadays.
Do you have a different key?
You might have a bad chip in the one you are using that is triggering the PATS system
AJ
Welcome to TRS :)
2000 Ranger V6 has PATS(passive anti-theft system), 1999/2000 V6 only, 2001 to 2011 all Rangers(except 2005, lol)
No, there is no by-pass for PATS, fix it or Tow it
I will assume you have driven the vehicle before buying it so it did run OK but the gas gauge didn't work
You dropped the tank or lifted the bed to look at or change sender/pump assembly in the tank
And after putting it back together you now get the "Theft Light"
None of that would effect a theft system, but could have blown fuses if wires got damaged
Theft Light is Flashing Rapidly with key on, NOT just on steady(that's an Alarm not PATS)
PATS should disable starter motor as well, so odd you can "crank it" but read on about battery voltage
After 45-60 seconds with key on theft light flashes code 1 6
11 Transceiver [transponder coil] not connected, or there is no power to it.
12 Transceiver internal fault.
13 No Key/no PATS key has been used to turn the ignition switch.
14 Incomplete key code received.
15 Invalid key code received.
16 CAN communications error.
In a 2000 V6 Ranger Code 16 means PATS module above Glove box can not communicate with the PCM(computer) in engine bay
So first thing, is the PCM turning on?
Watch the CEL(check engine light) on the dash, it will come on with key on, that means the Computer(PCM) has powered up, no CEL = No PCM and no start
Check PCM fuse and PCM relay in engine bay fuse box
Low Battery
Check battery voltage, key off, 12.3v to 12.8v is OK
Under 12.3v and voltage can drop too low when cranking, this resets PATS and it can't see PCM
In this case the Theft light should come on and then go off with key on, but would start to Flash Rapidly when cranking(voltage drop)
Welcome to TRS :)
Low Battery
Yes, test drive before buying...ran fine. Correct gas gauge didn't work. Lifted bed to change sending unit. All fuses we checked look good and had power coming to them. Yes theft light is blinking rapidly with key on then flashes code 16. No CEL. Both pcm fuse and relay have power going them. Battery with key off was 12.75.
Then No CEL is the issue and code 16 would also confirm Computer/PCM is not booting up
PCM relay should have two slots showing 12v with key on, only one slot key off(from PCM fuse)
2nd 12v slot is from fuse 19 in Cab Fuse box, same fuse powers the Coil Pack's red wire
Fuse 19 gets 12v with key on via the ignition switch and Maxi Fuse 5 in engine bay fuse box
PCM has 104 pins, pins 71 and 97 get the 12v from PCM relay when its activated
PCM also has 3 main ground wires, 76, 77 and 103, any of which could prevent it from starting if not grounded
Ok, so how do we fix it. Does it need replaced, reprogrammed.
Uh, he posted the troubleshooting information. You need to make sure the PCM is getting power and ground before you can tell if the computer needs something.
Just accept that your truck realizes you are a thief. Rangers are smart.
