drummerboy2012
- Oct 20, 2008
Hello fellow ranger lovers im new to this site my name is Andrew...I have a 1994 2.3 5 speed Ranger recentely ive been going through troubles with it. seems lots of people have similar problems too. Here's the problem...ill start it up and almost immediately idle surges take place jumping to about 1800 rpm then dropping to 500-600 rpm then back and forth until it warms up. it doesnt die out but, until i let it warm up idle is erratic. Thats the first problem, the second is once ive driven it around and shut it off and if i go to start it back up while the engine still warm it wont start until it cools down a little bit im totally confused on this one. I had a problem before a few weeks ago involving the fuel pump circuit being open code 543 i replaced the inertia switch and the relay the problem was solved but things were still wrong in other areas. if you need to know any specific details about any replacements or modifications ive done just ask. Im hoping someone knows what this is or have had similar problems because this sux. any help, advice, and technical assistance is greatly appreciated. thank you for your time.
