tigerpb
- Aug 26, 2007
- Automatic
My 2000 3.0 has a weird problem. I was lying in bed this morning, and was startled by the sound of my Ranger cranking itself over in the driveway! No one in it, no keys in the ignition!
By the time I got outside, it had stopped cranking over. I put my keys in the ignition, and switched it on. The dashboard and gauges lit up as usual. One odd thing, the CD ejected itself from the player when the key was switched on.
I then twisted the key and started the truck. It started right up. But, I could hear the starter still cranking while the truck was idling. I shut the truck off and the starter continued to crank. It cranked over for another 30 seconds, until the battery sounded like it was drained.
I'v never had anything like this happen on any car I've owned. Is this a common Ranger problem? The truck had the starter replaced about 6 months ago, but there's been no problems till now.
Any experiences with this? Could a bad relay, solenoid or ignition switch cause this?
BTW, I do not have a remote starter or after market alarm installed.
Thanks!
Thanks!
