SR185
I need some help with the power wires for the new head unit I am installing to (finally replace the stock am/fm cassette deck.
The dash as a plug with 3 wires that I'm trying to figure out. The stock unit plugged into these. One wire is yellow with black stripes, and it has power when the key it turned. The second wire is light blue with a red stripe: it doesn't seem to have power with or without the key on. The 3rd wire is orange, and it doesn't have power either.
The new harness says to connect it's yellow wire to the wire that has power when the key is on - I connected it to the existing yellow wire from the dash. The new harness has a red wire you are supposed to connect to constant power to keep the radio memory - I connected it to the light blue/red wire.
My new head unit will not power on. I have it's ground wire connected to the chassis. Any suggestions?
