Help Replacing Rear window on 92’
Calypso Ranger
Springfield MO
2.9 V6
31X10.50
I have a 92 ranger single cab with a sliding rear window. it has the two sliders. busted a piece of glass now i need to have the whole thing replaced... that’s fine but no one has the slider, only a single piece of glass. All glass places seem to say it will fit but some are worried i will need a different gasket... please help with some info if you have any. Will it go straight in? or will i need a new gasket as well? Will the single piece work? it’s supposed to be for the same model so. Thanks.
Suggest you stop at a truck cap dealer, they change the rear windows of trucks all the time, I'm sure they've broken a few over the years and probably have the answers, someone on the forum will have some answers also
Yes, the slider and solid are interchangeable. Yes, they use the same gasket.
If your looking for a used one, the 83-92 regular cab are all the interchangeable.
