help - replaced upper control arm and now I have 5deg camber
st-ranger
Mahwah, NJ
if it breaks - replace it with something better
2002 Ranger Edge 4wd- 3.0L
I just replaced the upper control arm on the driver side and the top of he tire is leaning in at 4.8deg.
i have the aftermarket adjustable bolts maxed out.
Could have gotten the wrong control arm?
what brand & part number did you get? did the upper ball joint stud mate properly with the hole in the top of the knuckle?
pics will help. do the old & new parts match?
The upper ball joint stud was the correct match for the spindle.
I can't believe it didn't think of checking the old one against the new one?!?
That's what I get for working in the rain.
I will take pictures tonight.
How did it work out? I'm interested in your upper control arm specs/size. a couple of us here are looking for a shorter upper control arm
to do a steering knuckle upgrade. so, if the "wrong" control arm is indeed shorter please post the specs and part number.
The control arms are the same, dimensionaly as the factory unit. its looking like the adjustment bolts are the culprit. Its not raining today so I will get out there and look a little more
