02 ranger
today, i changed my oil and i did not like the mess of wiring under hood from the e-fans. I would show yall a picture of the wiring schematic i use as reference but basically i have a flex-a-lite fan with thermostat wired to a relay. from the relay control side i have a wire running from switch inside the cab (i use this for the a/c) thru the relay to the battery. fan side i have it wired to the fan and grounds out on part of the chassis. This is wayyyyy over simplified. what i want is a way for my fans to turn on when my a/c is turned on and when the thermostat tells it too. i also want a fail-safe just in case something happens and messes up all controls so i can manually turn it on via a switch in the cab. How can i do this? Any ideas
thanks
thanks
