justin5717
- Jul 30, 2008
- Age
- 43
- Automatic
My nephew has a 94 Ranger 2wd 4.0L. He called me today and asked if i would come look at his tranny that is acting up. Problem is that it is not shifting. It goes into Reverse and Drive fine, but will not shift into second, third, or overdrive. I told him to put the selector in "1" and try to manually shift it into "2" to see if it will shift, no go. The tranny only shifts into second if you give it a lot of gas and kind of feather the gas to get it to shift. The last time i've been into a tranny was a 350 turbo. So my questions are, does this tranny have a governor valve (kinda what it sounds like to me)? If so, is it accesible from the outter part of the tranny? Is there a drain plug on this tranny, or should i just go ahead and buy a new pan gasket? Is there some type of filter or screen go into the pick-up in the valve body? Any help would be greatly appreciated. Thanks, justin
