2.3L ('83-'97) Help please. 89 2.3
MaD
AZ
2.3 (4 Cylinder)
Okay so I have a few questions and I'll attach photos for said questions. If someone can upload photos of the engines vacuum lines and coolant line I'd greatly appreciate it!!!
1.
This is off of the exhaust manifold and does anyone know the specific name for me to find a new one? Heat shield? I can't seem to find one.
2
Does anyone know where this line goes to?
3
What is this part called and is it possible to find new lines for it?
Thank you all for your time and help! Have a good evening.
Just off the top of my head; > fair warning < I can't guarantee accuracy and I may be using obsolete terminology.
1. Heat stove; supplies warm air to the air cleaner assembly.
2. Vacuum line for the HVAC system. I think the cut end would go to the vacuum source. See following.
3. Vacuum tree. Source of engine vacuum for systems and devices. Looks like you have at least one broken vacuum line, and any unused ports should have a rubber cap.
Mabey others will chime in to confirm or correct.
  • Like
Reactions: MaD
1.exhaust manifold shroud. I don’t know about buying a new one. @RobbieD got the other two.
