Help on installing coil spacers on a 97' Ranger xlt
Jhunter911
I have a 97' ford ranger with i beams all that is stock and i wanted to put coil spacers and i have tried and tried and i am almost there but i need a simple method then using two crowbars to seperate the spring to fit the spacers on the coil.... i have the bolt on ones i have tried and i think i need to put the rubber blocks in between the coils ?? any help please i would appricate it
Don't use those, they're bad. Get some that go underneath the coil, or make your own, like this.
Are you talking about these?
sports-imports_2065_30711162
Normally, if you get all the weight off the spring, and then use a 1/2" drive breaker bar you can 'twist' them in.
But I do not suggest using them..they can fly out and take out a testicle, or break your coils.
I suggest getting some under the spring, like milje suggested.
I have a scar from those type spacers they are kinda dangerous. Wasnt even my truck and I didnt pt them in, they came out at a mud bog.
