jcap
- Aug 13, 2013
1994 B2300
I just got the truck, I replaced the head and all the usual top end stuff as well as complete brakes and numerous other stuff. It runs great, (a bit of hesitation but it is a 4 banger with 200K plus). The first time I took a long ride the truck loses all power after maybe 20 to 25 minutes. It doesn't die or stall just bogs down with no power. If I let it sit 20 minutes its fine but the cycle repeats itself. I didn't check codes yet, but I did make a few changes that I am hoping someone can tell me if they could be an issue. I put in a oil, temp and volt gauge trio and removed the factory senders to utilize the ports (new gauges are mechanical), I did leave the temp sender that is in the heater hose connected. I also removed the RABS solenoid so I have a dim brake light and the yellow ABS light lit on the dash. Can disconnecting any of that stuff be causing my issue? I did the basic check all connections, check vacuum lines , fuel filter, its not overheating. I will go back to where I had to leave the truck now and see if I can figure out getting codes from it ( I am used to modern OBDII) and report back,
any help would be appreciated!
Thanks
Thanks
