Help Needed Please!
xfrog
I did a search and was unable to come up with what I need. I'm working on my 1993 4.0 Ranger 4x4 ext cab with 5 spd tranny. I pulled the tranny to have it rebuilt/repaired and I'm replacing the clutch and slave cylinder while I'm in there. I got the hydraulic line disconnected without any trouble, but it looks to need replacing. The steel piece of the line that attaches to the master cylinder looks extremely corroded and it would probably decide to spring a leak when I'm out in the middle of nowwhere. Can anyone tell me where to get a new one or a good used piece? To be clear, it's the hose that goes between the master cylinder and the slave cylinder. A part number would also help. Thanks.
most likely a dealer only item...which means dealer or junkyard (if you can find a decent one).
Clutchcityonline.com has them new for about $33.00 if I remember correctly. Ebay had them both new and used last time I looked there for parts. You are looking for the one with the gold colored fitting at the slave end of the line.
I got a used one from AllanD on this site a while back; if you ask he will let you know if he has one. Good luck.
