predator
I have a '91 ford explorer, 4.0,5spd,4dr. I did a SOA swap in the rear and I have installed 4'' drop brackets with 4'' skyjacker coils and extended the radius arms in front. It is sitting on 34x15x10.5 ltb's on 15x8 steel rims. The plan WAS to get 4.56 gears and lockers for the d35 and 8.8 and be happy, BUT I happened to have stumbled on a narrowed d44 set up for coil springs with 3/4 ton outers and 4.10 gears.
So now Im going to be doing a solid axle swap, but i wont get to use my tires because now im going to be 8 lug and need a 16.5 rim..
So i guess my questions are...What coil springs/buckets do i use? should i keep the 4.10 gears in the d44 and the (upcoming) d60 or should i change them? Is my master cylinder powerful enough to support the big dual piston brak calipers and the big massive drums in the back?i dont want to go over a 35'' tire, this vehicle needs to be streetable, the initial goal in mind when i started the build was ultimate hunting rig, that means it sees the road and sometimes the highway before it sees the hunting area..
so what do i do now?
