Ronald Meyers
- Sep 15, 2020
- Age
- 70
- 2.3 (4 Cylinder)
- Total Lift
- Stock
I've had this rager for about 7 years and I have never done anything to it finally just quit I'm a carpenter not a mechanic.
I read a lot and listened a lot and one year later I have it running but I still have some issues with some codes I need a little help my truck has a hundred and fifty-two thousand miles on it and I've just replaced the maf, the maps and the maps wire connector i hope is wired correctly and the idle air control, the PCV valve and I cleaned the hoses the PCV intake breather plate. The code readings I'm still getting are to lean bank 1 the po171 and I'm getting a p2195 O2 sensor stuck lean bank 1 sensor 1 I don't understand that and also cat system efficiency below threshold Bank 1 and the p1000 readiness test not complete so I don't know what those those are so anybody could help me out and I really appreciate it I didn't even know what sensors were until I tried working on this truck so now I respect everything about him and hopefully I'll learn more and keep it going for some time to come
