JeffyJingles
Hello everyone, so I have a 2004 ranger 4.0l sohc with 210326 miles on it. Two days ago I was driving in my neighborhood when my cel came one and began flashing. i ran the codes and got P0171 P0300 P0301. So i began to check my plugs, plug wires and coil pack. All were getting power to the plug and i even say spark. I decided i would have a check at the injector. I swapped the injector with the injector on cylinder 4 and still got the same three codes and trucks still running off one cylinder. Im guessing the lean code is all due to the misfire too. Anyone have any ideas on what else I could check?
Also, the truck was running fine until I decided to give it a tune up, by tune up I mean new intake plenum gaskets, throttle body gasket and IAC gasket. Along with the gaskets I cleaned everything real good with CRC throttle body intake cleaner. I have pcm scan tools checking stuff out but I can't pinpoint the problem.
