help me out please
madeforspeed
Can I use clutch and flywheel off my 3.0 on 4.0 what all do I have to change to do the swap. Its a 1998
They are two different motors, Bro. Find a 4.0 setup from the same year so it will all go together without any problems.
yeah, pretty much any engine size change in the ranger, you will need to change the transmission as well. (with the exception of the 2.9 to 4.0, they will interchange transmissions)
Check out the tech library and the engine and transmission forums, they will give you a little more detail.
AJ
