Stuntman Mike
- Jun 16, 2008
I broke something while spinning on ice/pavement.
It made lots of clanging and it was on and off catching(felt like jamming it into gear) and spinning freely(like slapping into neutral at throttle) for a short time after this happened. Now it won't catch with enough force to even move the truck on a level surface.
I removed the differential cover and I'll describe everything as best I can:
Driveshaft turns the main gear and carrier.
Rotating the rear wheels rotates the side gears in the differential.
Spider gears aren't turning, as in teeth not meshing.
I can put it in gear and then get out and watch the gears go round and round...
It makes a sort of "zzdtzzdtzzdtzzdt" like it's not catching more than the tips of the spiders. You can kind of feel it catch with very light clutch, but more engagement makes it give up and spin around aimlessly.
7.5 Trac Loc.
Fluid was slightly silvery-silky in color when I started to drain it but mostly black after.
Only visible damage I have seen inside was the eaten pieces of half a tooth from the main gear. The debris added up to just that much, so I assume there's not any more carnage besides that.
If anyone could give me some idea of what's going wrong, I'd appreciate it.
I don't really have money to replace 'costly' parts...
If it comes down to it I can weld it solid.
I don't want to, but it's the cheapest option.
7.5 Trac Loc.
