Help me, bad missfire!!
RandyL
Ok so i need some help here ...
97 ford 4.0 in a b4000
Ok i have a really bad missfire... Cyl 3 is just dead theres just raw fuel like a mist comming out of the tail pipe and it just smells of gas ,
the cyl has 120psi wet , I put new injecters, o2 sensers new plugs swap coil packs and wire, maf, no light but i ran a real scaner on it and pulled a few hiden codes
Checked fuel psi its at 40psi running and 40psi when it primes but it bleeds down when its not running and well hold if it was running... This is why i did my injecters ... But same poo after they where done and there was no gas in my vacum line when i was checking the fpr .
So if anyones up to slap some ideas at me :) i wont get mad thanks
And all top end gaskets and o-ring where done 5 months.
And when i pulled the pugs in bank one (pass side) are black ex cyl #3 soked in fuel, and bank 2 plugs are all mint.
Computer? Or a crank sensor? Or maybe It's a bad connection between the two?
Codes with this issue?
P0603,p1116, p1000,p1132,p1127and p1408 .... I took out my egr along time ago , and i did the test and it was not at full temp... To much gas pissing out to let anything get hot
Ok so i can get a computer from a 2000 ranger with ohv for free so well that work? And i'm going to swap out a bunch of sencers today with my buddys truck so i hope somthing happens :s
