ranger rob
I have an 87 with a 2.9. It has typically been a great truck. Lately it has been issue after issue. I recently had to replace the distributor in response to a faulty hall effect switch. In the process of chasing down possibilities I checked the fuel filters and replaced the in line filter and installed a canister type filter. There wasn't even one in it! I put on a new cap and rotor as well as a new ignition control module. Once I dropped the new distributor in place everything was awesome.
Now not so much. I've only put about 3000 miles on since the distributor issue. Currently I'm dealing with loping and idle issues. It will still run, but I have to give it some throttle to get it to move. When coming from a dead stop, it has no throttle sometimes. I have to put my foot in it to get it up to decent rpms. Once at higher speed it seems to run decent, but at a lower speed it lopes and bucks like I'm hitting the brakes or the clutch.
Here is a list of things i've done.
-replaced plugs and wires
-checked and replaced throttle position sensor with an old used one
-pulled egr valve from plenum to clean it, but didn't get very far. couldnt get it off the exhaust tube. cleaned what i could get at.
-plugged egr entrance into plenum with no real change.
-checked fuel pressure, no issue
-checked map sensor, no issue
-pulled off rusty old exhaust muffler, no change, but it's louder!
-poured a bottle of seafoam in, no change
-checked ignition control module, no issues
-pulled the battery cables off to see if that does anything, now it barely runs.
I'm stumped!!! I could really use some help with this! Thanks!
