fairman86
- Mar 6, 2011
hey guys, i have a 98 mazda b2500
just did the timing belt on it, timing marks are all aligned, truck will start usually with out a problem, but when cold has one hell of an idl issue, it will acually shake the truck. when you blip the throttle it will knock then rev, if you go slowly into the throttle it struggles for the first 800rpm then smoothes out and will rev pretty good above 2000 rpm, while cold if you rev it up to about 3-4k rpm and let off it will retun to barely an idle knocking and shacking sometimes stall sometimes sort itself out. once warm it seems to idle fine while just putting around town no faaster than 60km/h
i tried to take it on the highway today and on ramp in third it is pretty slow to hit 80, then 4th to go above 100 is quite the stuggle, if i put my foot harder into the throttle it dosnt really pull any harder. to maintain highway speeds its pretty sluggish, then once i come off the highway and come to the first stop sign on thw off ramp, it barely idles and stalled, but fired right back up and with a little convincing it ran smooth again, and puttered around town no poblem not going above 60km/h
i have taken out and cleaned the map sensor, i have a new egr tube, i tried taking the vacuum tube off the egr valve and plugged it, seems a little better but still does the same stuff. i ran a scan tool, im not sure what it means but it says my "short term" fuel was at 33 and my "longterm" fuel was at 3. i am going to put a new fuel filter on it tonight and pull the tps and clean it, any other suggestions?
