cougar190
Help ! Have to rev. engine to go into drive.94 Ranger UPDATE 11/13/12
Recently my wifes 1994 Ranger STX 4.0 A4LD 4X4 started giving us fits. Reverse works fine. But when you put it into drive it just sits there, haven't seen if it will eventually go into gear but if you rev the engine (popping the throttle) up a ways 2500 to 3000 it will drop into drive and work just like it supposed to. But if you shift into reverse or park when you go back into drive it happens all over again, nothing till you pop the throttle again. When it goes into gear it doesn't Slam but goes normally. I've done a fluid and filter change, fluid was Nice and red with a few fuzzies on the magnet. Problem still there. Any questions , just ask I'll try to help. ...cougar...
