Rabbit
- Dec 17, 2007
- Automatic
I'm hoping someone here has dealt with this issue before. Ok, for starters, the basics: '88 B2, 2.9l, A4LD auto, 4x4. I have recently replaced the following in response to the problem: Fuel pumps, filter, and fuel control relay. Now for the problem: the damn thing will run just fine for a few weeks and with no warning at all the fuel pump will lose power. It doesn't matter if it was turned off and then back on or if i'm cruising down the highway, it will just stop working. After leaving the truck parked overnight I can go out in the morning and it will respond as if nothing had ever happened. It will go fine for 2-3 weeks then do it again. I'm completely stumped. It's actually losing voltage at the pump and I can't seem to find a short or a loose connection. Any ideas?
