help from collective brain
doug95sc
Peoria, AZ
Have 89 bII-will install high-pin. 44 in front & d-60 rear. Will be running 37" tires. Want to extend front axle forward & use coil susp. & links. Any pointers? Have BW 1350 t-case. can e- shift 1354 be used to build doubler? Does rear Explorer spring swap yield ample flex? Have about 800 more questions but will start with these! Thanks.
e shift tcases can not be used as the doubler. well, not with out alot of work. the manual case is much easier to deal with. have you looked into the D20/1354 doubler?
Haven't heard of the d-20-1354 deal. Do you know what rbv's had a manual 1354?
