HELP flasher don'T work
Québec,Canada
I have an inspection mechanical but my flasher doesn't work but my 4 hazard light work (the relay under the dash where steering colum is okay) ...
where is the another relay for the turn light flasher !? do you have another opinion for my problem !?
thank you very much
sorry for my bad english !!:buttkick:
do you still have the flasher relay? cuz that happened to my friend 85 c20 the signals wouldnt work but the 4 ways did. it looks like a cicular relay with like 5 prongs coming out the bottom
i think rangers have them hope this helps
i never touch my flasher relay because i don'T know where is it ??? the hazard and flasher are not the same ??!?!?
pass 2 month they work very great until today
the relay should be under the driver side dash by the pedals i think, see i though they were on the same relay to but my friends truck they werent but ill have to check out my truck to see where the flasher relay is an ill let you kno
thank you very much !!! tu blue one relay was dead !!! my truck is ready for the inspection at all .... the only thing is my fan climate control work just in 4th speed ... all other is off 1,2,3 and the 4 work at max speed .... ?!
