Help deciding on a lift?
bridgetf
I have a 2004 Ford Ranger 2wd and I want to put a body lift on it. I would like to fit 33" tires. Would a 3in body lift work? And does anyone have any pics of what it looks like together? I want to make sure it looks good before I spend all the money on everything. First time dealing with lifts!
Go to the 2wd forum area and you will see a lot of lifted 2wd trucks there and advice on installs, which works, which does not work. Use the search function on the site and see what you pull up.
:icon_thumby::icon_thumby:
lift
Depends what engine you have a 2.5 or even a 3.0 will have a tuff time pulling the 33's with out regearing and also a recaliberation device, I have a 99 withn 31's and there is still lots of room for 33's see posts titled 99 undates bigger does not always mean better looks, plus the rack and pinion set up is a little on the weak side
