ri06667
- Jan 16, 2008
Last night my engine made a thump and the check engine light came on. It was running fine when i gave it gas, but when i idled at stop lights it was the rpm was fluxuating between 500 and 800rpm and it sounded like it was barely running.
I checked the codes on the engine and it brings up these two:
116 - Engine Coolant Temp higher or lower
538 - Insufficient Revolution Per Minute Change Dynamics
Truck is a 92 2.3 5spd.
Temp gauge on the dash works fine and never goes higher than normal, it wasnt particularly cold out yesterday either.
Any suggestions welcome!
