dirtdobber
- Jun 27, 2009
- 2000 3.0 ranger
I have a 2000 ranger flex fuel with 3.0 I spun the bearings in it when the fuel pump fail do to the gear failure on the rod that runs up to the sensor. I rebuilt the motor and put the motor back in the truck no it throws the code saying cam sensor circuit failure I replaced the cam sensor and it still misses, and the check engine light I have noticed it also throws a code saying cylender four misfire, but when I pulled the plugs cylender three was the only plug that was black so I thougt the coil might be jumping inside so I replaced it and it still misses. I was wondering if any one knows the correct voltage that goes to the cam position sensor? HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
