Cube911
- May 11, 2009
I have a 91 Man 4.0l, The problem I am having is that at the accumulator switch I am getting voltages through the accumulator switch but it is not making it to the compressor. I have ohmed from the hot side of the compressor to the fuse and its closed as I imagine it should be, but only with the ignition off. Once the ignition is on then it is "open" and doesn't start the compressor. I can jump the compressor on, and it cools properly, freon is "close enough for govt work". With the a/c switch inside on, the truck seems to act as if the a/c was working properly, idling differently compensating for the a/c, but no clutch spinning. I have checked the wiring through the engine compartment and it is all properly intact.
My only solution is going to be to run the power from the accumulator switch to the compressor, if nobody can lead me in the right direction. I will leave the accumulator switch of course inline. But in Ga A/C is a MUST!!!
Thanks
Jason
Thanks
Jason
