Alby1
- Dec 20, 2016
I have an '09 ranger 2.3 4cy 2x4 w 5 speed manual trans. It just now has about 17,440mi. It had 10,600mi on it when i bought it in March. It had sat alot. How long at one time im not sure. My prob is after it has been driven 10-20mi of city/town stop and go it has a shutter(not a jerk) when shifted into 1st and on occasion into 2nd that i feel in the rear end. It happens as clutch is engaging and stops when the clutch is fully engaged.I do not feel it in the clutch pedal. Untill it has been driven for this long it shifts smooth as butter. If i baby it and shift into 1st VERY slowly it does not do it at all or rarely. It has to be shifted so slowly it is not viable to do in trafic. My ASE mechanic drove it today. At 1st he said he thought it might be the drive shaft/rear diff. since he had seen similar issues in older rangers(2001). After investigation he found that it has a different drive shaft/rear diff so now believes its clutch chatter. It goes into his shop thurs, said he will try to rule out any prob like drive shaft,rear diff, springs or u joints. If other probs are rulled out then it must be clutch chatter. There is no loss of clutch fluid or engine oil, which i believe would rule out main seal or slave cyl leaking on clutch disk. There is an examination window on the trans covered by a rubber boot of sorts. I pulled the boot back to chk for any fluid in bell housing and there is none. I find it hard to believe clutch could be glazzed w so few miles. Or any prob w clutch at all w only 17,440 miles on it. Maybe rust spot on fly wheel? My question is has any one else had this same or similar prob w an '09 ranger? Or maybe a different model yr close to '09? Am i missing something simple like chg rear diff. fluid? Any insight or imput is greatly aprieciated.
