Hellp with measurements
D walker
Hello from the road.
I bought a 1987 ex-cab shortbed Ranger that I won't pick up till spring and could use some help. Searching I found the longbed a 6" longer wheel base so if anyone has a truck like mine, could you please measure the distance from the back of the cab to thr center of the rear wheel. Also need from the back of the door to center of rear wheel.
Doesn't need to be exact.
Thanks Dwight
What's your goal? Frame swap?
Mid-engine v8 power glide and a quick change IRS rear end. Looking to see how far into the cab I need to go. Or if switch to long bed fiberglass bedsides.
Pre-runner/sand truck
Looks to be 39 inches from the back of the cab to the center of the rear wheel well and 5 feet from the back of the door.
Thank you very much. I sure hope there is someone close to me that needs some parts when I start this truck. I am only using the cab and doors. The donor truck is my avatar.
