hello everyone,i'm twayne410 from florida
Merry Christmas to you too! And welcome to TRS!
hello bobby,i have a 1994 mazda b4000 and it runs bad.i found that the coil is fireing weak on the 2 middle outputs of it and replaced the coil but new coil does the same thing.you wouldn't by chance know what the problem is?i have 2 ideas but not sure,thinking of the cam sensor or the ignition control module.
runs bad means so much to so many.
obvious misfire? plugs indicate the issue? how did you measure the weak spark? wires tested good i assume?
fuel pressure is correct?
often vacuum leaks cause stumble along with false air to the air meter or simply a dirty air meter.
i pulled the 2 middle wires off the coil and used a test light and there was barely any spark then i tried the other 4 and they sparked real strong.when i put a spark tester on the end of the 2 wires no spark is there unless you adjust it until it almost touches,but on the other 4 the tester was opened up over a 1/4 inch apart and the spark was strong. has all new ngk plugs and new wires
