Profleet
- Jul 3, 2013
- Automatic
Just joined your very informative site.A few tips from a old wrench puller with Rangers,#1 rear spring mounts oil the crap out of them "as in rust proof" or they will rot out and you will have a leaf spring mount through the truck bed. #2 Ignition control Module,crank sensor,before buying new and expensive replacements for no start or running like shat,cut into the harness and check that the black to yellow single wire with connector off the crank sensor harness has not rotted off inside(seen this few times)if it is thats your problem and relocate you ICM off the manifold ,heat kills them(mine is mounted on a plate on top of the power steering bracket where the A/C pump would go..#3 for guys that need smog checks and are suffering high Nox numbers pull your spout connector and take her back for a sniff,9 times out of 10 she will pass with the spout pulled#4 for you guys running a auto trans Ranger,put a after market trans cooler on it inline with the factory rad cooler and change the trans oil and filter once a year(cheap insurance).Sorry about my computer skills.... Cheers guys
