Helga, My 88 B2 Build...
Well I've decided to go ahead and regear a 31 spline 8.8 I have laying around since I cant find any with 4.56s local. I've already ordered an Aussie for it since they go out of stock ofter figured I'd better do it now. I've found package deals on Yukon 4.56s with master install kit for $230 as well which I don't think is half bad, I'll also stick in a crush sleeve eliminator while I'm at it. Just need a few tools and this should be an interesting experience.
what comprises this crush sleeve eliminator you speak off???
I believe it's just a solid spacer.
Started work on my sliders agian yesterday, got the passenger side mounted up today, I will be running one more brace down to the bottom of the frame rail and it will use the same holes as the t-case skid plate. The main mounts bolt to the body mounts on the frame. The drivers side will be a bit more tricky because of the parking brake cable. The last picture it's hanging down a bit further than it it normally does because the bolts werent tight. They stick out a bit further than I anticipated but it'll give a bit more protection from things from the side and it'll be easier to get a hi lift on and you can stand on em as well.
looking good,
yeah the eliminator is a solid spacer and some shims.
on a side note i thought it was funny i used my left over tiny shims for the eliminator on my brothers d30 when we set it up.the 4.56 R&P and bearings are tiny in those axles
Drivers slider mounted up. Need to do the middle mounts for triangulation, and paint em and they should be good to go. Also need to weld up a couple brackets for the E brake cable, should have done it when I did the body lift in the first place anyways.
lookin good man. Sliders are one thing thats on my list. Made a bling set for the g/f's jeep this summer. Now I just got to get around to making my own.
hey by any chance do you have any 4.10 gears you could sell me after you upgrade?
Possibly my 7.5 (minus the locker) if non of my friends want it.
sweet I really like that style. Any chance you can show how they bolt up. and what bracket you used. thanks
ok just send me a message or ill send you one and ask once its out alright, thanks.
Another bumper down, built for my friend's yota.
Fixed a couple things on the B2 like the windshield motor that was slowly taking a dump on me for the last year, and my license plate light wires shorted out and popped the fuse for my tail lights and dash lights so I had to track that down.
Maybe finish up the sliders this weekend.
Thanks, already have another person who wants one built for their XJ. Here's a slightly better view of the yota bumper.
