Automan1988
I have a 1991 ranger with a 2.3 and just installed a new water outlet housing, 192* t-stat and heater hoses. The truck is not getting up to temp, and the heater is blowing cold. The only way I can get any heat out of the heater is to rev the engine up and then you can feel it start to blow warm, but not like it should be, and as soon as you let off the throtle the heater cools back down. It has a coolant flush kit on it and when I loosen the cap coolant is dumping out so I know that there is flow in the system. Any ideas on why it will not warm up or blow warm air.
