Heater core
lokitwitch04
Nashville MI
So Im sure you guys have been asked this a thousand times but I have to go to work in like 5 hours and its starting to get cold. I just changed the radiator in my truck today because I hit a deer at the beginning of summer and it has benn leaking ever since. Well I let the truck warm up and take it for a spin to make sure everything is cool. On my drive I flip it to dfrost turn it to hot and turn the fan on high speed. Instantly my window fogs. WTf. iS MY HEATER CORE SHOT. I hope not. I dont smell coolant in the truck but also dont know where the heater core is. its a 89 2.9 BTW. ranger. I need help ASAP. Thanks in advance.:dunno:
nothing leaking into the cab or on the ground? usually a hose or clamp, but could be the core. the new rad undoubtedly has more pressure than the old leaky one and maybe it blew something out. i feel your pain... in the high 20's here last night. i am so NOT looking forward to another northern Minnesota winter!! :bawling: good luck!
btw, did you replace the thermostat at the same time? just another thought.
Your heater core is easy to get at. Under the glove box are 5 plastic screws which hold on the trim which hides the heater core. Drop the trim and look at it.
Just hitting a deer shouldn't have killed your heater core. Are you sure you weren't just blowing moist air onto your wind shield due to humidity and your A/C not kicking in?
