RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
Just another " heads " question. The heads in question are the 4 valve heads on the 4.6l and 5.4l engines specific to the intech family in the mark viii's, continental's, and navigators. The 32 valve aluminum 4.6l engines (named teksid, for the manufacture) in the mark viii's and continentals are near identical, with the continental engines having a slightly detuned version for the front wheel drive. All 32 valve 4.6l engines were the same except for the 03-04 cobra motors having a 4 bolt iron block, all others were a 6 bolt aluminum block. The 32 valve 5.4l found in the 99 navigator, also using the intech name, is said to share the same design of the 4.6l iron intech block. Later year navigators dropped the intech name.
So now that the history lesson is over (and what I found out from researching), what I haven't found out is there any difference in the 4.6 and 5.4 heads? If so, what differences are there, and what years apply, if any.
As extra credit, what fuel system (return/returnless) does the 4.6 intech run, and when and what (vehicle) did the throttle body switch to DBW (drive by wire)? I found an 01 continental that has returnless fuel system and DBW. I know the continental was detuned for front wheel drive duties, but dont know if the rating (260hp vs 280hp of the mark viii) was just a tune or hard parts. Let the discussion begin...
SVT
SVT
