Headliner comparable years.
Kencraft
Eudora Kansas
Hi need to get a headliner board for my 99 2 door XLT extended cab. I found that the 4 doors are different shape. My question is what years should I be looking at, that will fit?
You should be good with 1998 - 2011, as long as the cab style is the same. They didn't change the cab drastically since the 1998 remodel.
93-97 supercabs *may* work. The cab was the same and from 95 on had the same dash. I don’t yet own a 3rd gen though so I can’t confirm.
98-11 should fit fine. As you discovered, the extended cab doors change things a bit, so be selective.
