Headlight wires
American1990
Conyers, Ga
Build it, Break it, Re-build it stronger.
Ok, I have a 1992 Engine bay wiring harness and a 1989 Dash harness. The 89 had a 2.9 and I used the stuff from a 1992 ranger to do a 4.0 swap. everything works fine but when I switch on the head lights things don't work right. So I pulled both of the wiring harness (engine bay and under dash), and I under stand how the Engine bay wiring harness works and what colors are what, but what I cant figure out is for the under dash harness what wiring are for high beam and low beam, (I have been using this as a bases to work off ofhttp://www.therangerstation.com/tech_library/WiringByColor.html but some things don't make sense like the wire that suppose to be for low beam the red and black goes to the steering column where you would click to turn on your high beams). I know I should be using Electrical Diagrams but I just don't understand them, call me dumb but they just look Spanish to me. I just need help wiring the wires from the head lights to the rights wires for the switch. I know I could just run a new switch but then I would have to run a switch for High beams, low beams, parking lights, and tail lights, or find one that does most of it.... I just need a little guidance...any help is VERY much appreciated. :dunno:
If you have a 89 b2 and used a 92 4.0 harness everything should plug and play
The b2 and ranger use the same multi switch for lo beams and hi beams it also controls turn signals and hazard lights as well as windshield wiper delay
You need the entire 92 4.0 engine harness
Remove the old 2.9 harness the mainconnection is the big white plug, on the drivers side this houses all the headlight connections, then you remove the 2.9 engine harness that connects to the computer on the passenger side
Connect the 92 big white plug to the 89 bobwhite plug snake the engine harness where the old one goes and everything should be golden,
If your headlights aren't working I would check the grounds along the front core
Sent from my iPhone using Tapatalk - now Free
