Ron the ECU 00+ model strategy they use for E85 is called adaptive learning, I had a really good article explaining this that I found from Ford engineering, short explanation is that they use the O2 signal, re-fuel data, and some other information to approximate the ethanol content in the tank & adjust to a 14.7 AFR, it is a guess at best. In my case on a supercharged engine it is a nightmare. I will see if I can find the article and post it.
I have ran blends of up to 50% E85 and premium and the ECU gets lost, I get poor performance, very rich and at times, mostly idle & low RPM I get the 171/174 codes. I have even seen this on straight 93 octane, this has to be the dumbest idea that Ford has came up with as the adaptive learning really has very few true data inputs to determine what is in the tank.
So far the best all around performance I can get from blending is with 89 octane with 20% E85, runs great, hardly ever throws the codes & does not go into that extreme rich mode while cruising at 60+ mph like it does with the blend & premium.
JP02XLT
