2.3L ('83-'97) Head bolt torque -- how bad did I screw up?
Tennessee
Stock
Stock
Made a silly mistake in swapping my 1995 2.3 head gasket.
New Fel-Pro head bolts and head gasket. Threads were dry with no sealant though the bolt holes weren't perfectly dry.
I accidentally read an older service manual and torqued all the head bolts in 2 stages to 50 and then 90 foot-pounds.
Looked it up, and Fel-Pro as well as a ton of other places say I should have done the revised torque spec of 51 foot-pounds and then 90 degrees.
How big of a whoopsie? Do I need to get another set of head bolts and another head gasket and try again?
So the real question is why was the spec changed?
Are different bolts listed for the earlier spec?
I believe so, yes. Forum wisdom says that the original bolts were not torque to yield and could be reused, and sometime in the 90's a new TTY bolt replaced it.
If they are indeed TTY, I'm sure most people would say get a new set and try again.
This is probably terrible advice so take it with a full pinch of salt. I'm thinking that with 90 degrees, your final torque is going to be a fair amount higher than 90 pound feet. My gut tells me those bolts are probably still fine. If I were in a pinch or feeling brave, I'd be tempted to just do the procedure again. I usually chicken out though. Let's get some guru feedback here.
Edit: unless the procedure specifically forbids it, I'd definitely very lightly oil the threads and under the bolt heads.
It's probably a wash either way considering if you're staying stock power output... but if you're worried you could back the bolts out one at a time until they're loose then just go to the TTY spec... if I had to guess the TTY spec is tighter than standard so you're most likely safe using the bolts again...
If they're torque to yield bolts, don't reuse them. They're meant to stretch during the 90 degrees and they may break or not torque properly a second time. A new gasket would a good investment, too.
I'd hate repeating the job, too, but I'd hate it worse if I had to extract broken headbolts from the block.
I would loosen one. Mark the head and beside with a paint pen first so you can see the orientation before and after. Then torque using the 90°. If the mark lines up or goes farther I would reuse.
Oiling will allow greater stretch with the same torque. Find out if its supposed to be oiled or not...
In other words not oiling may have saved your butt if its supposed to be oiled.
Which begs the question . . . what weight butt oil do you recommend?
And, do they make a synthetic for that?
Inquiring minds want to know . . . :)
Event Coverage
TRS Merch
