2.3L ('83-'97) Head bolt torque -- how bad did I screw up?
Tennessee
Stock
Stock
Made a silly mistake in swapping my 1995 2.3 head gasket.
New Fel-Pro head bolts and head gasket. Threads were dry with no sealant though the bolt holes weren't perfectly dry.
I accidentally read an older service manual and torqued all the head bolts in 2 stages to 50 and then 90 foot-pounds.
Looked it up, and Fel-Pro as well as a ton of other places say I should have done the revised torque spec of 51 foot-pounds and then 90 degrees.
How big of a whoopsie? Do I need to get another set of head bolts and another head gasket and try again?
So the real question is why was the spec changed?
Are different bolts listed for the earlier spec?
I believe so, yes. Forum wisdom says that the original bolts were not torque to yield and could be reused, and sometime in the 90's a new TTY bolt replaced it.
If they are indeed TTY, I'm sure most people would say get a new set and try again.
This is probably terrible advice so take it with a full pinch of salt. I'm thinking that with 90 degrees, your final torque is going to be a fair amount higher than 90 pound feet. My gut tells me those bolts are probably still fine. If I were in a pinch or feeling brave, I'd be tempted to just do the procedure again. I usually chicken out though. Let's get some guru feedback here.
Edit: unless the procedure specifically forbids it, I'd definitely very lightly oil the threads and under the bolt heads.
Event Coverage
TRS Merch
