Have a bushing question
Popeye
I just purchased my first Ranger, a 95 XL, 2wd, 5spd. The radiator core support was rotted and the support bushings were toast. I went to LMC and tried to purchase the bushings and they don't have all the parts for a 95. I then got some prothane bushings that stated they fit 83-97 and they don't fit. The original oned are oval with rubber and a plastic. I emailed them with the enclosed pictures and the reply was I don't know why your truck has oval bushings, send them back if you can't get them to fit.
Oh I forgot to say I removed the whole front end and cut the bushings out.
So after all that has anyone encountered this or have a solution to a fix for this?
I searched for an answer in previous posts and didn't find anything similar.
Thanks
Here's a shot of the mount
Thanks for all the help this site rules!
:icon_confused:
die grind the hole out round and put them in
for the record that shape hole is called a "Double D"
It is round with two flats, like an electrical outlet.
MAkE the bracket fit your bushing
Thanks for the reply
I'll do that. I was concerned with the potential of forward and aft movement.
