Hey guys,
First time posting on this site, figured you guys could help me out here
Okay the deal is i recently decided it was time to give the old 2.9 a new life. I pulled it cleaned it all up and sent it to a local machine shop to do all the work.
They cleaned up the block, bored it .30 over and put a torque profile on the cam. I had them re-assemble the bottom end of it seeing as they already had it and i built the top.
Now since i have this thing back in the truck and everything hooked up for the life of me i cant get this stupid thing to run....it cranks and cranks to no avail, if you unplug the fuel pump relay, then connect it it will barely start but die unless you have the throttle pinned.
I have swapped the distributor, throttle sensor, plugs wires cap, MAP sensor, coil and TPS. Fuel pressure is a steady 38-40 psi, i have plenty of spark. the one thing that throws up a flag is i only have 100-105 for compression on the cylinders, i know its a new engine and the rings most likely havent seated yet but i still see that as low.
So if anyone has any ideas... they would be appreciated because i am stumped!
