motorman105
- Dec 31, 2008
- Automatic
My 2005 Supercab 4X4 4.0 liter has 112,000 mi. No modifications. Oil changed regularly. I had the 100,000 mile check done and a new fuel filter installed. I'm the original owner.
From the time I bought it new....once I turn the key, it would turn over and immediately start up. A few months ago I noticed every once in a while it would take a few more seconds of turning over to start. Now it takes about 4 seconds of the engine turning over to start and it happens almost all the time. If I turn the ignition to on then wait a few seconds..then engage the starter it starts right up but that doesn't always work. I thought it might be the fuel pump but when I'm driving on the thru-way, the truck accelerates fine. I was thinking maybe the fuel pump relay might be screwing up. I have not had the fuel pressure tested. It doesn't seem to matter if I'm parked on a level surface or not. Could there be a problem with the fuel filter? I asked my mechanic to check it but of course the truck started right up for him every time.
Any ideas?
Thanks!
Any ideas?
Thanks!
