- Nov 18, 2007
- Port Huron, MI
- Automatic
All you need for your motherboard can be found here:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2NPV-VM
Although I don't see anything in the specs for the BIOS updates that talks about drive size it wouldn't hurt to install the latest one anyway. From what I understand you should be able to dump the update to it using a flash drive and there should be something in the manual about how to do it. All of your drivers for it and even RAID support for XP64 can also be found on that site if you needed it.
I just got done looking through the same site. Hopefully this works cause the partition did not change anything.
or
