Geof
- Oct 28, 2007
- Age
- 48
- Automatic
Hi I have a hand brake problem on a ranger 1999 4x4 with 10" drums. I just change all rear brakes ( spring, shoes and drum ) I have also change rear hand brake cables.
Normally hand brake of ranger don't need adjustment. When I activate the hand brake It never put enough of pressure on drum to retain the truck on a small slope. I have activated the hand brake lot of times without success. other symptom, when I release the hand break, the pedal not totally return in initial position. It needs I pull the pedal to place it at initial position.
What is the problem.
Thank you
Thank you
