Hammerman
hammerman
Culdesac, Idaho
Temp fluctuation
Temp fluctuates ,normal then like the thermostat opens goes to cold, 5 min. Of driving goes up rapidly to normal maintains the temp. 30 sec. Then drop to cold. Cycle repeats. Replaced thermostat with 192 degree still did it.
Had bad valves so changed heads, water pump still does the same thing.
Check gauge sensor for proper operation. Not that loose connection or bad ground. Did teflon on threads of gauge sensor? English not hard. Welcome to forum.
