- Jan 14, 2009
- SoCal
- Total Lift
- 4.5" SL
- Total Drop
- WWWhhhaaattt !?!
- Tire Size
- 33 x 12.50
I painted the grille of the 03 black, a little shinier than I wanted but it will have to work.
here are a couple of pics.
This is where it all started. washed out grey.
http://s219.photobucket.com/albums/...er/?action=view¤t=GrilleBeforePaint.jpg
This shows the inner shell shroud; it was oxidized and needed to be really cleaned.
http://s219.photobucket.com/albums/...ger/?action=view¤t=InnerGrilleShell.jpg
This is the grille after paint. A little shaky, the flash didn't work for some reason; I will get another tomorrow.
http://s219.photobucket.com/albums/...nger/?action=view¤t=GilleAfterPaint.jpg
Wider view of the finished grille, another shaky one.
http://s219.photobucket.com/albums/cc292/Scrambler82/03 Ranger/?action=view¤t=GrilleAfter2.jpg
There are 6 mtg tabs on the lower lip of the grille shell, they do pull out but watch it, you can pull too far and damage the shell.
I cracked the shell, easy fix with fiberglass but something that may have been avoided.
Also, when and if removing the grille from the shell be careful here too.
I was very careful after cracking the shell but two of the grille mounting tabs broke off.
You can see in the pic there is a repair along side of the grille too.
http://s219.photobucket.com/albums/cc292/Scrambler82/03 Ranger/?action=view¤t=MtgTabs-6.jpg
Here is the repairs Pic.
http://s219.photobucket.com/albums/.../?action=view¤t=RepairtoGrilleShell.jpg
On a bright red Ranger the black looks great, glad I did it evenif I had to repair the shell.
While it was apart I did the Side Marker/Turn Signal Mod in another thread here on the site.
That worked out great, looks the balls.
I added 194 LED Lamps at the same time, they look OK - no pics.
